How to take a screenshot
I’ve found here that many people do not know how to make a screenshot on the computer. I decided to write how to do it.
The procedure is simple to disgrace: in order to take a picture of the whole screen, you need to press the PrintScreen key on the keyboard. To make a screenshot of only the active window, you have to press both the PrintScreen and Alt keys simultaneously. These same combinations usually work on Linux machines.
The screenshot will be copied to the clipboard, after that you can open the program where you want to paste it, and insert it yourself (ctrl + v)
If you want to take a screenshot of only a certain section of the screen – then you can use the standard program – scissors. In it you can specify the area that you want to take a picture, as well as a mouse to specify a window, etc.
After removing the screenshot, you can save it, copy it or send it by e-mail.
Posted on 07.08.201730.05.2024 by sanglyb
← How to disable the password when you exit Windows sleep mode
Migrating sites from IIS7 to IIS8.5 →
