How to download and install Office 2024 LTSC
An example of how to download and install Office 2024 LTSC, Visio, Project and Skype for Business.
  • Download the latest Office Deployment Tool.
  • Run it and unpack it somewhere.
  • Go to that folder and edit the config. As an example, configuration.xml:
<Configuration>
  <Add OfficeClientEdition="64" Channel="PerpetualVL2024">
      <Product ID="ProPlus2024Volume">
	  <ExcludeApp ID="OneDrive" />
	  <ExcludeApp ID="Teams" />
	  <ExcludeApp ID="Lync" />
	  <ExcludeApp ID="Groove" />
      <Language ID="ru-ru" />
    </Product>
    <Product ID="VisioPro2024Volume">
    </Product>
    <Product ID="ProjectPro2024Volume">
    </Product>
    <Product ID="SkypeforBusiness2024Volume">
    </Product>
  </Add>
</Configuration>
You can view the list of product codes here. Configuration options are available here.
  • Download the files:
setup.exe /download configuration.xml
If it complains that it cannot download, you can try doing this:
reg add "HKCU\Software\Microsoft\Office\16.0\Common\ExperimentConfigs\Ecs" /v "CountryCode" /t REG_SZ /d "std::wstring|US" /f
  • Install Office:
setup.exe /configure configuration.xml
  • Activate (use at your own risk, just for experiments 😉 ):
irm https://get.activated.win | iex
I chose TSForge from the menu.
Posted on 11.11.202511.11.2025 by sanglyb
← How to Collect Statistics on User Calendar Events Using a Script?
How to remove attachments from old calendar events in Exchange using a script →
