How to remove attachments from old calendar events in Exchange using a script
Another interesting task came up, which is a continuation of one of the previous ones. It was necessary to create a script that would remove attachments from old past meetings.
The script is based on the same approach as before — attachments will be removed using EWS. Accordingly, the account running the script must have impersonation rights.
For example, you can add permissions like this:
New-ManagementRoleAssignment -Name "AllowImpersonation" -Role ApplicationImpersonation -User sanglyb@yourorg.com
New-RoleGroup -name ImpersonationGroup -Roles ApplicationImpersonation
More details about permissions and roles can be found in the reference guide.
As usual, I uploaded the script to GitHub — if anything changes, that version will most likely be the latest.
When running the script, you must specify the required parameter -Mailbox — the mailbox where the script will search for appointments, in the format user@yourorg.ru.
You can also set report mode (-report $true), in which case only statistics will be displayed, without deleting attachments.
Additionally, you can set the search depth in days and your EWS address either in the script or through parameters.
Example:
./remove_attachements.ps -Mailbox user@yourorg.ru $false -DaysBack 90
It’s important to understand how the script works: it finds an event in the specified user’s calendar, checks who the organizer is, and if the organizer is not the user, impersonates the organizer via EWS, removes attachments (if the meeting is in the past, or if it’s a completed recurring meeting), and sends updates to all attendees.
This means the update may be sent to multiple users. Therefore, use the script with maximum caution and at your own risk!
Below is the script itself:
param(
    [Parameter(Mandatory=$true)]
    [string]$Mailbox,
    [switch]$Report=$false,
    [int]$DaysBack = 60,
#    [string]$Output = "past_meetings.csv",
    [string]$EwsUrl="https://exchangeserver/EWS/Exchange.asmx"
Write-Host "> Mailbox: $Mailbox" -ForegroundColor Cyan
Write-Host "> Report:  $Report"   -ForegroundColor Cyan
Write-Host "> EWS URL: $EwsUrl"   -ForegroundColor Cyan
# bypass certificate errors
[Net.ServicePointManager]::SecurityProtocol = [Net.SecurityProtocolType]::Tls12
[System.Net.ServicePointManager]::ServerCertificateValidationCallback = {
    param($sender, $certificate, $chain, $sslPolicyErrors)
    return $true
function New-EwsService {
    param(
        [string]$ImpersonateMailbox,
        [string]$Url
    $svc = New-Object Microsoft.Exchange.WebServices.Data.ExchangeService(
        [Microsoft.Exchange.WebServices.Data.ExchangeVersion]::Exchange2019
    $svc.UseDefaultCredentials = $true
    $svc.Url = $Url
    if ($ImpersonateMailbox) {
        $svc.ImpersonatedUserId = New-Object Microsoft.Exchange.WebServices.Data.ImpersonatedUserId(
            [Microsoft.Exchange.WebServices.Data.ConnectingIdType]::SmtpAddress,
            $ImpersonateMailbox
    return $svc
function Get-Appointments {
    param(
        [Parameter(Mandatory = $true)]
        [Microsoft.Exchange.WebServices.Data.ExchangeService]$Service,
        [DateTime]$Start,
        [DateTime]$End
    # splitting the range into 30-day chunks
    $step = 30
    $calendarFolders = Get-CalendarFolders -Service $Service
    $allAppointments = @()
    foreach ($folder in $calendarFolders) {
        $chunkStart = $Start
        while ($chunkStart -lt $End) {
            $chunkEnd = $chunkStart.AddDays($step)
            if ($chunkEnd -gt $End) { $chunkEnd = $End }
            # CalendarView for 30 days
            $view = New-Object Microsoft.Exchange.WebServices.Data.CalendarView(
                $chunkStart, $chunkEnd, 1000
            $view.PropertySet = [Microsoft.Exchange.WebServices.Data.PropertySet]::FirstClassProperties
            try {
                $page = $Service.FindAppointments($folder.Id, $view)
                if ($page.Items.Count -gt 0) {
                    $allAppointments += $page.Items
            catch {
                Write-Warning "Error reading folder $($folder.DisplayName): $_"
            # next chunk
            $chunkStart = $chunkEnd
    return $allAppointments
function Get-OriginalAppointment {
    param(
        [string]$ICalUid,
        [DateTime]$Start,
        [DateTime]$End
	$appointments=Get-Appointments -service $service -start $start -end $end
    foreach ($appt in $appointments) {
        try { $appt.Load() } catch {}
        if ($appt.ICalUid -eq $ICalUid) {
            return $appt
    return $null
function get-calendarFolders {
    param(
	$root = [Microsoft.Exchange.WebServices.Data.WellKnownFolderName]::MsgFolderRoot
	$folderView = New-Object Microsoft.Exchange.WebServices.Data.FolderView(10000)
	$folderView.Traversal = [Microsoft.Exchange.WebServices.Data.FolderTraversal]::Deep
	# filter by folder type
	$searchFilter = New-Object Microsoft.Exchange.WebServices.Data.SearchFilter+IsEqualTo(
		[Microsoft.Exchange.WebServices.Data.FolderSchema]::FolderClass,
		"IPF.Appointment"
	return $service.FindFolders($root, $searchFilter, $folderView)
function Get-Master {
    param(
        [Microsoft.Exchange.WebServices.Data.Appointment]$OrgItem,
        [Microsoft.Exchange.WebServices.Data.ExchangeService]$OrgService
    if ($OrgItem.AppointmentType -eq "Occurrence") {
        return [Microsoft.Exchange.WebServices.Data.Appointment]::BindToRecurringMaster(
            $OrgService,
            $OrgItem.Id
    return $OrgItem
function Save-OrgItemAndSendUpdate {
    param(
    Write-Host "`nRemoving attachments from event $($OrgItem.Subject)..." -ForegroundColor green
    try {
        $OrgItem.Attachments.Clear()
        $OrgItem.Update(
            [Microsoft.Exchange.WebServices.Data.ConflictResolutionMode]::AlwaysOverwrite,
            [Microsoft.Exchange.WebServices.Data.SendInvitationsOrCancellationsMode]::SendToNone
        $OrgItem.Load()
		# modify meeting body to ensure proper update notifications
        #$OrgItem.Body = New-Object Microsoft.Exchange.WebServices.Data.MessageBody (
        #    $OrgItem.Body.Text + "<p>Attachement removed by script</p>"
		$body = $OrgItem.Body.Text
		$body = if ($body.EndsWith(" ")) {
			$body.TrimEnd()
		} else {
			$body + " "
		$OrgItem.Body = New-Object Microsoft.Exchange.WebServices.Data.MessageBody $body
        $OrgItem.Update(
            [Microsoft.Exchange.WebServices.Data.SendInvitationsOrCancellationsMode]::SendToAllAndSaveCopy
        Write-Host "Event update completed" -ForegroundColor Green
    } catch {
        Write-Warning "Error updating event: $($_.Exception.Message)"
        if ($_.Exception.InnerException) {
            Write-Warning "Inner: $($_.Exception.InnerException.Message)"
$service  = New-EwsService -ImpersonateMailbox $Mailbox -Url $EwsUrl
$startDate = (Get-Date).AddDays(-$DaysBack)
$endDate   = (Get-Date).AddDays(1)
$appointments=Get-Appointments -service $service -start $startDate -end $endDate
$groups = $appointments | where-object {$_.HasAttachments -eq $true} | Group-Object ICalUid,AppointmentType
Write-Host "`nPreparing data..." -ForegroundColor Green
$allItems=@()
$results = foreach ($grp in $groups) {
    $item = $grp.Group | Select-Object -First 1
    $item.Load()
    if ($item.End -ge (Get-Date)) { continue }
    if (-not $item.HasAttachments) { continue }
	if ($item.AppointmentType -eq "RecurringMaster" -and $item.LastOccurrence.End -ge (get-date)) { continue }
    if ($item.AppointmentType -eq "Occurrence") {
		if ($item.Attachments.Count -ge 1){
			$itemTMP = Get-Master $item $service
			if ($itemTMP.AppointmentType -eq "RecurringMaster" -and $itemTMP.LastOccurrence.End -ge (get-date)) {
				$test="skipped"
				continue
			} else {
				$test="not skipped"
				$item=$itemTMP
	$allItems+=$item
    [pscustomobject]@{
        Mailbox          = $Mailbox
        Subject          = $item.Subject
        Start            = $item.Start
        End              = $item.End
        Organizer        = $item.Organizer.Address
        HasAttachments   = $item.HasAttachments
        AttachmentsCount = $item.Attachments.Count
		Attachments		 = $item.Attachments
        ItemType         = $item.AppointmentType
        ICalUid          = $item.ICalUid
		IsCancelled		 = $item.IsCancelled
		LastOccurrence	 = $item.LastOccurrence.End
		skipped			 = $skipped
$allItems = $allItems | sort-object {$_.Organizer.Address}
if ($allItems.count -eq 0){
	Write-host "No calendar events with attachments found." -ForegroundColor green
	exit
} else {
	write-host "Old calendar events with attachments found" -ForegroundColor green
	$results
# if Report is specified — only report, no cleanup
if ($Report) {
    Write-Host "`nReport mode. Attachments will NOT be removed." -ForegroundColor Cyan
    exit
# Clean
$item=$null
	foreach ($item in $allItems){
		$organizer = $item.Organizer.Address
			# --- if the organizer is another person ---
		if ($organizer -and $organizer -ne $Mailbox) {
				try {
					if ($prevorganizer -ne $organizer) {
						Write-Host "Impersonating $organizer" -ForegroundColor Yellow
						$orgService = New-EwsService -ImpersonateMailbox $organizer -Url $EwsUrl
						$prevorganizer=$Organizer
					$origItem = Get-OriginalAppointment -Service $orgService -ICalUid $item.ICalUid -start $item.Start.AddHours(-2) -end $item.End.AddHours(2)
					if (-not $origItem) {
						Write-Warning "`n`n`nOriginal meeting not found in organizer's mailbox. Removing attachment from user $mailbox ..."
						Save-OrgItemAndSendUpdate $item $service
						continue
					$origItem.Load()
				} catch {
					Write-Warning "Impersonation error: $($_.Exception.Message)"
					continue
				if ($origItem.AppointmentType -eq "Occurrence") {
					$itemTMP = $null
					$itemTMP = Get-Master $origItem $orgService
					if ($itemTMP.AppointmentType -eq "RecurringMaster" -and $itemTMP.LastOccurrence.end -ge (get-date)) {
						Write-Warning "Last occurrence date has not yet passed..."
						continue
					} else {
						$origItem=$itemTMP
				Save-OrgItemAndSendUpdate $origItem $orgService
		else {
Write-Host "`nCompleted" -ForegroundColor Green
Posted on 11.12.202511.12.2025 by sanglyb
← How to download and install Office 2024 LTSC
Problem Using PassFiltEx on Older CPUs →
