Sometimes it is necessary to open all selected files in Total Commander, for example, when searching by content, that would edit these files. To do this you need to add an icon to the toolbar total commander.
To do this, right-click next to the icons and click Edit.
In the window that opens, click Add, and fill in the fields:
The command is the path to the program in which we want to open files (in the meme this is the path to notepad ++ – “C:\Program Files (x86)\Notepad++\notepad++.Exe”)
Parameters – %P%S
Icon file – select any icon.
Click OK, on the control panel you will have to see a new icon. Now select several files and click on this icon, all selected files will open simultaneously in the program you specified.
Related video (Russian language):
